Documentation Conventions
This page describes how the schema documentation in this repository is structured and how to contribute new or updated documentation pages. If you are adding a new schema, updating an existing one, or improving documentation quality, this guide will help you follow the established patterns.
Documentation structure​
The documentation is organised to mirror the three-tier schema hierarchy:
docs/schemas/
├── index.md # Schemas landing page
├── objects/ # Object schema documentation
├── components/ # Component schema documentation
├── elements/ # Element schema documentation
└── generated/ # Auto-generated content (do not edit)
Each tier has its own directory containing an index.md (a domain-grouped listing of all schemas in that tier) and individual documentation pages for each schema. The generated/ directory contains auto-generated flat property tables and UML diagrams — these are produced by make generate-schema-docs and must not be edited manually.
The _category_.json files in each directory control Docusaurus sidebar labels and ordering. Objects appear first, then components, then elements — reflecting the top-down hierarchy that most readers will follow.
Page templates​
Object schemas​
Object pages use the full template with lifecycle badging:
import OverlineWithVersion from '@theme/OverlineWithVersion';
import SchemaUri from '@theme/SchemaUri';
import FlatProperties from '../generated/flatmd/objects/<name>-<version>.md';
<OverlineWithVersion title="Geoscience Objects" version="<version>" badge="<supported|techPreview>" />
# <name>
<SchemaUri uri="schema/objects/<name>/<version>/<name>.schema.json" />
<!-- Key components (if object uses specialised components) -->
<!-- See also (if related objects exist) -->
<!-- Description -->
## Properties
<FlatProperties />
::mermaid[../generated/uml/<name>-<version>.mmd]
The badge attribute reflects the schema's lifecycle state as described in the Schema Development Lifecycle. Use "supported" or "techPreview" as appropriate.
For objects with multiple documented major versions (e.g., gravity), use version-suffixed filenames: gravity-1.2.0.md, gravity-2.0.0.md.
Component schemas​
Component pages follow a similar structure but omit OverlineWithVersion (components do not have independent lifecycle states):
import FlatProperties from '../generated/flatmd/components/<name>-<version>.md';
# <name>
<SchemaUri uri="schema/components/<name>/<version>/<name>.schema.json" />
**See also:** [related-component](related-component.md) (relationship description).
**Used by:** [consuming-object](../objects/consuming-object.md).
## Properties
<FlatProperties />
Element schemas​
Element pages are the simplest. Most elements are stable primitives and rarely need lifecycle badging or extensive cross-referencing:
import FlatProperties from '../generated/flatmd/elements/<name>-<version>.md';
# <name>
<SchemaUri uri="schema/elements/<name>/<version>/<name>.schema.json" />
<!-- Description: data format, encoding, width/shape semantics -->
**See also:** [related-element](related-element.md) (relationship description).
## Properties
<FlatProperties />
Writing descriptions​
Descriptions should help a reader understand the schema's purpose and role without needing to read the raw JSON. Focus on:
  • What the schema represents and when it is used.
  • Key properties — call out important fields, especially those with non-obvious semantics.
  • Relationships — how this schema connects to others in the hierarchy.
Keep descriptions concise. The auto-generated property table already documents every field; prose should add context, not duplicate it.
Cross-referencing​
Cross-references help readers navigate between related schemas. There are three types:
"Key components" — composition references (objects only)​
Links from an object to the specialised components it composes, giving readers a forward-navigation path. Only include components specific to the object or a small family — skip ubiquitous components like locations or scalar-attribute:
**Key components:**
- [survey-collection](../components/survey-collection.md) — Logical grouping of survey measurements
- [survey-attribute-definition](../components/survey-attribute-definition.md) — Common properties for survey measurement attributes
"See also" — peer references​
Links between schemas at the same tier that share a relationship (siblings, counterparts, dimensional variants):
**See also:** [vertices-3d](vertices-3d.md) (3D counterpart).
"Used by" — consumer references​
Links from a schema to the schemas that directly reference it, one tier up (component → object, element → component):
**Used by:** [drilling-campaign](../objects/drilling-campaign.md), [downhole-collection](../objects/downhole-collection.md).
Skip "Used by" for schemas that are referenced so broadly that listing consumers adds noise rather than value (e.g., base-spatial-data-properties, attribute-list-property, most array elements).
When multiple cross-reference types are present, the ordering is: "Key components" (objects only) → "Used by" (components/elements only) → "See also" → ## Properties. Structural relationships (composition and consumption) take precedence over the less-structured associative "See also" links.
Maintaining cross-references​
Cross-references are bidirectional and must be kept in sync when schemas are added, removed, or refactored:
  • Adding a new object: Add "Key components" entries on the object page for any specialised components it uses. Update each referenced component's "Used by" line to include the new object.
  • Adding a new component: Add a "Used by" line listing the object(s) or parent component(s) that reference it. If the consuming object has a "Key components" section, add the new component there as well.
  • Renaming or removing a schema: Search for all cross-references (Key components, Used by, See also) that point to the old name and update or remove them.
  • Version-bumping a schema: After running clone_schema.py, update doc page imports and cross-reference links to point to the new version where applicable.
When in doubt, grep the docs/schemas/ directory for the schema name to find all references that may need updating.
Index pages​
Each tier has an index.md that groups schemas by functional domain rather than alphabetically. This aids discoverability — a reader looking for drilling-related schemas can jump straight to the relevant section.
When adding a new schema, add it to the appropriate section of the relevant index page. Each section should have:
  • A brief summary sentence between the heading and the first entry.
  • Entries in the format: * [Display name](file.md) — brief description.
  • Ordering from general/abstract to specific/concrete within each section.
For multi-version objects, use sub-bullets for version links:
* Gravity — potential-field gravity survey data
* [1.2.0](gravity-1.2.0.md)
* [2.0.0](gravity-2.0.0.md)
Deprecation notices​
When a schema is deprecated, add an alert immediately after the <SchemaUri> line:
import Alert from '@mui/material/Alert';
<Alert severity="warning">
This component is deprecated and will be removed in a future schema version. New integrations should not rely on this component.
</Alert>
Annotate the entry in the relevant index.md with (deprecated). Keep deprecation messages factual — state that the schema is deprecated and advise against new use, but do not reference unreleased replacements or internal services.
Generating documentation​
After creating or modifying schemas, regenerate the flat property tables and UML diagrams:
This populates docs/schemas/generated/. Always run this before opening a PR that includes schema changes. If a generated file is not produced for a particular schema (this can happen for schemas that use pure allOf composition with no additional properties), replace the <FlatProperties /> tag with a prose note directing the reader to the base schema's properties.
Checklist for new documentation​
  • Doc page follows the appropriate tier template (object, component, or element).
  • Description explains purpose and key properties.
  • Cross-references are present and bidirectionally consistent:
    • Objects: "Key components" lists specialised components (with em-dash role descriptions).
    • Components/elements: "Used by" links to direct consumers one tier up.
    • "See also" links to related peers where a natural relationship exists.
    • Each "Key components" entry has a corresponding "Used by" on the target component.
    • Each "Used by" entry has a corresponding "Key components" (or inline reference) on the consuming object.
  • Cross-reference ordering follows convention: Key components → Used by → See also → Properties.
  • Schema is listed in the correct section of the tier's index.md.
  • make generate-schema-docs has been run.
  • Page renders correctly in a local build.
Was this page helpful?
