Coordinate reference systems and axis order
The Coordinate Reference System (CRS) for spatial / geoscience data is critical to uniquely locate each datapoint relative to the Earth and to other datasets. Evo takes a strict approach to CRS, consistent with other leading implementations (e.g., PROJ > v6.0; see below).
Every spatial Geoscience Object carries a coordinate_reference_system as part of its base-spatial-data-properties. The CRS is the single source of truth for how the object's coordinates should be interpreted: it defines the order, direction, and meaning of each coordinate axis.
The schema field labels x, y, and z (and the bounding-box fields min_x, max_x, min_y, max_y, min_z, max_z) are positional labels for the first, second, and third CRS axes. They do not imply easting, northing, and elevation or any other inferred coordinate ordering. To interpret a coordinate correctly, read the object's CRS first.
CRS representations​
The crs component supports three representations, exactly one of which must be provided:
  • epsg_code — An integer EPSG code from the EPSG Geodetic Parameter Dataset.
  • ogc_wkt — A WKT2 string. Axis order is declared explicitly in the WKT2 AXIS clauses.
  • An unspecified CRS (no properties), used when the coordinate reference system is unknown or not applicable.
For both epsg_code and ogc_wkt, the axis order, direction, and meaning are those declared in the CRS definition — not an assumption made by the schema or by consuming software.
The rule​
The order, direction, and meaning of the coordinate axes are defined by the object's coordinate_reference_system, following the axis order declared in the CRS (its WKT2 / EPSG definition). The labels x, y, and z denote the first, second, and third CRS axes — consumers must not infer the meanings of these labels.
This mirrors the modern PROJ (version 6 and later) philosophy of being strict about CRS-declared axis order rather than silently assuming an easting-first ordering. See the PROJ FAQ, Why is the axis ordering in PROJ not consistent?, for a clear rationale.
Worked example: axis order matters​
Consider a point whose first two coordinate values are (500000, 400000).
EPSG:2180 (ETRF2000-PL / CS92, Poland) declares its axis order as (northing, easting) — the first axis points North, the second points East. A UTM zone such as EPSG:32633 declares the opposite order, (easting, northing). The same pair of numbers therefore describes two different ground positions depending on the CRS.
The transformation below uses pyproj to convert the point from EPSG:2180 to EPSG:4326 (WGS 84 geographic, axis order latitude, longitude). The always_xy flag on Transformer controls whether the CRS axis order is honoured. always_xy=False (the default) honours the CRS-declared axis order and is the correct setting here. The use of always_xy=True forces an easting/longitude-first ordering and silently swaps the coordinates in many CRS configurations, e.g.:
import pyproj
epsg_4326_gps = pyproj.CRS.from_epsg(4326) # WGS 84 geographic, axis order (lat, lon)
epsg_2180_poland = pyproj.CRS.from_epsg(2180) # axis order (northing, easting)
# Honours the CRS axis order — always_xy=False is the default (CORRECT):
t = pyproj.Transformer.from_crs(epsg_2180_poland, epsg_4326_gps, always_xy=False)
print(t.transform(500000, 400000, 0))
# -> (52.356819022127155, 17.531162579943917, 0.0) # (lat, lon, z)
# Forces easting/longitude-first, ignoring the CRS axis order (WRONG for this CRS):
t = pyproj.Transformer.from_crs(epsg_2180_poland, epsg_4326_gps, always_xy=True)
# -> (19.0, 51.466568940540256, 0.0) # (lon, lat, z) — swapped, wrong location
Interpreting the coordinates as easting-first, when the CRS declares northing-first, places the point in the wrong location. The only generally-correct approach is to defer to the CRS.
Non-cardinal and reversed axes​
Deferring to the CRS is necessary because axis order is not the only variable — axes can also point in non-cardinal directions or increase in the "wrong" direction. For example, EPSG:2065 (S-JTSK / Krovak, Czechia) is a Křovák projection whose first axis points South and whose second axis points West. Increasing the first coordinate moves a point south (latitude decreases); increasing the second coordinate moves it west (longitude decreases).
You cannot infer axis order, direction, or meaning from the field names x, y, z. Always read them from the CRS.
Bounding box​
The bounding-box min_*/max_* fields give the extent along the corresponding CRS axis, not necessarily easting, northing, or elevation:
  • min_x/max_x — extent along the first CRS axis.
  • min_y/max_y — extent along the second CRS axis.
  • min_z/max_z — extent along the third CRS axis.
Contrast with GeoJSON​
Readers coming from a GeoJSON background should note an important difference. GeoJSON fixes its coordinate reference system to WGS 84 (RFC 7946, §4) and always orders coordinates longitude, then latitude, then elevation (§3.1.1 "Position"). This fixed longitude-first ordering (equivalent to urn:ogc:def:crs:OGC::CRS84) is why GeoJSON differs even from EPSG:4326, which uses the same WGS 84 datum but is latitude-first. Geoscience Objects do not pin a CRS this way — they defer to the object's coordinate_reference_system, so both the CRS and the coordinate order can differ from GeoJSON.
Producer and consumer guidance​
  • Producers should write coordinates (and bounding-box extents) in the CRS's native axis order, and set coordinate_reference_system to describe exactly that ordering.
  • Consumers should read the CRS before interpreting any coordinate. A consumer that natively supports arbitrary CRSs can use the coordinates directly in their declared order; one that transforms to another CRS should use a library that honours CRS-declared axis order (for example, PROJ ≥ 6 / pyproj with the default always_xy=False). Be flexible on read: do not assume easting-first.
References​
Was this page helpful?
